gusu
- 1,950
- 35
- Sep 9, 2009
Independence,
Oregon
So the other day I bought all new belts because they had been destroyed when my AC pulley's nut fell off and the belt wrapped its self around the other belts.
Anyway, today I hear the most ungodly squeal from the belts. So I opened the hood and noticed about a 1/8th of an inch had been scrapped off the power steering belt from rubbing on the alternator tensioner, and not just the bolt but the bracket (box looking thing) that both bolts go into (The one that bolts it to the alternator).
What's really odd is no matter how I moved the PS pump, even all the way back it would not stop rubbing the tensioner. When I went to adjust the tension on the alternator it was as tight as it would go so I couldn't make any room at all for the tensioner to stop rubbing on the PS belt from that end.
I don't know if anyone has encountered this problem before but I just find it very odd it would randomly decide to do this crap when it was fine all week. Now there seems to be no possible way to get them to not rub. I also noticed the alternator tensioner bracket that bolts to the block (The long bracket that bolts near the water pump and is kind of boomerang shaped) would not have the "fork" on the end hit the tensioner bolt no matter how much I would attempt to move the alternator... it never had a problem before. I 110% remember that it was indeed on that stupid little bastard fork the last time I tightened the belt because it was such a bi*** to hold the other end of the bolt while trying to adjust the tension.
Anyway, does this make sense to anyone or is some damn magical elf playing a trick on me and making my car defy physics and logic?
