spyderdrifter
- 5,426
- 860
- Jul 11, 2009
Somewhere in,
Colorado
After my recent awd swap being completed, I have learned that the 7 bolt I put in with the swap, is suffering early symptoms of crankwalk, being that the crank trigger plate is hitting my cps while disengaging the clutch. It is an oem spec clutch disc, pressure plate, and tob, with the only aftermarket part being a Fidanza flywheel. But, this post is not about this engine as I already have a plan to take care if the issue.
This post is about this.... eventually, I want to build a 4g64 stroker engine. I know all engines are capable of crankwalk, but has the been as much of an issue with 4g64 engines like 4g63's. Do they have the same premature bearing failure or crank failure?
