420A Cranks no start (420a)
Gavinrich25
80
Jul 26, 2021
Roanoke, Virginia
Now now before you say check the threads I have and have seen doesn’t sound right so here some background on the car...
it is a 1997 Mitsubishi eclipse rs model
It cranks slowly somtimes but it does crank and if sombody has a reason why somtimes it’ll be fast then somtimes slow that would be nice but back to the point...
it has fuel- pressure it has spark in ever cylinder and the crank position sensor is also good and it seems like it wants to start it just won’t commit
I have not done a compression test yet as I am waiting for tmr...
it has “started “ today as this problem has only been a day thing due to tranny being locked up if the trans is off would that stop it from starting? Like I said it has started once just for a split second but that’s the closest I’ve gotten.....
like I said it has fuel and spark and it is not a orange spark if that helps and I have not tried to read codes yet I’ll do that tmr but does anybody have any ideas?
And I will add when car starts all lights are on srs, oil, etc
And another thing I seen people talk abt the anti lock my door handles don’t work so does that have anything to do with?
Start with clean all the ground points and with new battery and make sure terminals are also clean, I've seen people mix up CAS and ignition sensor wires (since 2gb has same plugs for both) so make sure if you or anyone else has messed up anything with them that they're not mixed up
Alright I’ll start with that thank you
Definitely sounds like an electrical issue. Get the battery, alternator, and starter tested. Wouldn't hurt to replace them all if you have the budget for it, they are 25 years old.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
