crankcase cover gasket leaking
buddy3824
120
Mar 31, 2009
lexington, Kentucky
ive just bought a 92 gsx and it appears that the crankcase cover seal is seaping a lot of oil. the car is losing a quart of oil about every 120 miles and it is my daily driver. the turbo return line is leaking a little bit but minimal compared to this.
my main question is.. how much work and time would it take to replace that gasket and is there somewhere else i should look for leak? oil pan looks good, ive put dye in it and thats rly the only place i see leaking.
Congrats! You own a Mitsu that leaks! ROFL
The crankcase.. which i believe your talking about the oil pump front cover...
Is easy to replace IMO... just time consuming..
It requires a timing belt job and basic no how of how to replace a seal/gasket
Labor wise... you can probably find a side-working-mechanic to do it for about $250-$400 (that's what we charge)
While your at it, replace the cam seals ;) its part of the timing belt maintenance that should always be taken car of....
haha :hellyeah:
well, the engine was rebuilt about 5000 miles ago and the timing belt and everything was replaced then, balance shaft removed also :sneaky:
i am a mechanic myself, but ive never replaced this kind of gasket and the software i own didnt tell me how to replace the seal, so its not a big :aha: for me. i just didnt wanna get involved in a huge job and need my car the next day. id probably end up beating myself up :banghead:
probably, but ive got reciepts for most of the stuff, so i know MOST of it was replaced. i put almost 600 miles on the car every 2 weeks, so the leak is pretty bad in my mind, since ive made the first post, ive put 2 quarts in it. it sucks, but it runs like newborne ;)
