2G Crank Scrapers? Thoughts on them? Benifits?
Th
I just seen these by accident and they look pretty good for keeping oil in the pan.. Was wondering if anyone had any experience with these things.. Thank you for any input.. Ohh and Windage Trays ??? Combo of both work well??
Those are more of a serious racer thing, the thought process behind it wind tray prevents oil slinging onto the crank, scrapper wipes it off the crank- less oil on the crank=less weight/rotational mass so it'll make a pony power more to beat the other guy sounds dumb but bracket racers do every little thing to be one up. Knife edging the crank weights is also another way makes it cut thru the oil more efficient...or get crazy n do a dry sump set up no oil pan it's all in a resivor mounted somewhere else with typically a electric oil pump.
The other reason these benefit is oil starvation which is the biggest reason for spun rod bearings on something like the 420a and if I could find one that wasn't expensive I'd have it.
