420A Crank Bolt
HPfreak
44
Jan 24, 2006
Jackson, New Jersey
Hey guys, i have a big problem! i was working on my car recently and i noticed that the crank pully bolt was completely stripped out and i need to change the t-belt and waterpump. I believe that on the 420a motors you have to use a puller to get the crank pully off but if the bolt is stripped out how can i get it back on. So i was wondering if anyone would have any cheap suggestions on how i can fix this problem. Thanks Alot!
Personally i think Heli coils suck a$$. Try to clean up the threads with a tap.
hey, when i noticed the bolt it was just sitting in the crank pully and when i pulled it out the threads on the bolt looked fine so im assuming that the threads in the crank shaft are stripped. Thanks.
