cracked head, fixable?
602gsx
72
Dec 19, 2010
phx, Arizona
hey guys, i was driving to work this morning and the car started overheating on the highway. It had a leak so i put water in the radiator then on the way home it started over heating again so when i got home i looked around and found a small crack about the thickness of a hair and about a 1/4" long.. is it fixable?
It would be different if you had some insane porting you didn't want to get rid of...but there are bare stock head cores in the classifieds all the time for $50-$75. Get one of those, take it to your machine shop where you get all the discounts- have them deck it, swap the valves from your head over, and install new seals. Good for another 150K. LOL
You must of gotten that thing very hot. I had a beater non turbo 4g63 that i drove over 10 miles in the red and didn't even crack the head. Was there actually coolant coming from this crack? Also where was the crack located? There are only a few places externally on the head that cooling could leak thru if cracked. 99 percent of the time it will happen in the combustion chamber or runners.
I see cores all over the place for cheap, get one and rebuild it, easy enough, i never had a cracked head, but i used to have several cores back in the day.
