Please Support RTM Racing
Street Build 94allwheeldsm's Talon TSi AWD
Ownership Status
Currently Own
Eagle Talon TSi AWD
Automatic
Build Type
  1. Street
DragNFly Performance T3 twin scroll manifold, 6 blade Holset 40 w/stock 18cm housing, Copper manifold gasket, Tial MVS 38mm wastegates, Magnus heat barrier gasket, EGR block offs, fuel pump rewire, Gates racing belt, full 3" exhaust, Aeromotive 340, Aermotive filter, Fuel lab afpr, 8an feed, 6an return, 1050cc FIC, JMF 7gal fuel cell, 105amp Saturn alternator w/1g pulley, Jay's racing alt reloction, FFWD FFOFH, Snow Performance Meth kit (625cc nozzle)(380cc secondary coming soon)
Mods-Engine
SIM 2.3 6 bolt (stock 2.4 crank,wiseco 8.5, eagle h beam, ARP mains,ACL race bearings, oem BSE, str8 cut Oil Pump gears) balanced) w/7 bolt N/T head, GSC S2's, Kiggly Ti beehives, SS valves, oil port mod 2
Mods-EMS & Logging
Jackal/Ostrich, Aem 5 bar, GM IAT, Autometer Carbon Fiber (WB, Boost, volt & remote mounted oil pressure gauge), cheap oil temp gauge
Mods-Drivetrain
4 bolt LSD rear, Kiggly wiring mod, Garage Built Auto with, Kiggly 5 disc front clutch, shift kit with modified valve body, Sinister 9", IPT high flow pump, welded center, kiggly flexplate w/ARP, Mishimoto HD cooler, hy gard
18" Falken torque 5's, General G-max AS-03, DBA 4000xs rotors, Hawk pads, Tein SSP, RTM rear subframe bushings, energy suspension front subframe and control arm bushings, bulfab mustache bar, True Street cross member w north south bars,
Parts Wishlist
Slicks, tubed front, n2o
  • Like
Reactions: MOONDUST
94allwheeldsm
Comments
More in 1G DSM
Share this Vehicle
