Could a broken FPR cause idle surge / running rich & poor mileage?
killerwhale
128
Aug 10, 2007
Victoria, BC, Canada
Let me know what you think.
If yes, my HP goals are about as much as the stock engine can handle so my question is should I go AFPR, or get a replacement?
If no, wtf do I do? I checked for vac leaks and found 1 tiny hole in one of the MAF solenoid hoses and fixed it. Boost leak test found all kinds of crap (throttle body gasket, upper intercooler hose, intake hose, etc.) - fixed. I've blocked off the FIAV, replaced the ISC, new plugs & wires, brand new ECU, cleaned the throttle body, checked the EGR, replaced the o2 sensor, replaced the coolant temp sensor... When I replaced the plugs, they all looked fouled.
Thanks
bump
