Poor idle/running rich from bad o2 sensor?
vpr131
30
Aug 9, 2012
Tampa, Florida
Hey guys,
After starting up my dsm, it idles pretty high and eventually comes down after about 10 minutes of driving. However, after this amount of time at a stop/idle, it begins to choke and go down to about 300rpms, almost die, and then come back up again. It will repeat this process until it eventually turns off. Also, when I am driving, if I go in to neutral, sometimes the rpm's will fall down all the way and the car will completely shut off.
I originally thought it was a vacuum leak (it may still be although I have checked most hoses), loose clamps, or even bad gaskets. I recently checked for codes and I found that the o2 sensor is bad. Could this be the reason for my bad idle and extremely rich condition. I am blowing lots of black smoke out of my exhaust upon hard acceleration. Thanks
With a bad o2 sensor the ecu will lock itself in open loop mode creating a very rich mixture to prevent damage to the motor. So order and install the new o2 first, because it says it's bad, and go from there. I had a similar issue and it solved it for me. So start there and see what you're left with.
Also is your bov recirculated? And if it's not are you running a maf with a translator? You should update your profile with your mods so we can help some more
