running rich, idle surge, CEL
green_GST
32
Feb 24, 2008
Warner Robins, Georgia
Symptoms:
-CEL
-idle surges @ 1200-1600 rpms, unless I disconnect the throttle idle sensor, then it sits at 1500 rpms.
-AFR at constant idle is 12
-AFR when it's idle surging goes from 11-17+
-While driving, over 2000 rpms, the AFR drops below 10 and won't accelerate anymore unless it boosts, then it sits at 10.3ish. Under 2,00 rpms, the AFR is 10.3-10.5
All the sensors look to be connected, and it's boosting right so it's not a boost leak.
This all started last night. Out driving and it was running right, get home and let it idle before I shut it off and it starts out of no where. My mods list is up to date, except I now have a big 16g.
:dsm:
Ok, we did the old trick using a LED and wire and jumping it from pin 12 to pin 1. It's throwing a code for the "volume air flow sensor" (according to VFAQ.com) We tried 3 different MAF's and nothing changed, still has the same code, is the MAF different from what they're saying the code is? If not, then what gives?
