DSM Jeff
- 558
- 7
- Jun 23, 2003
Connecticut
Well its finally nice and boss let me out 2 hours early with pay!.
Anyway, heres how I did my battery switch on my 90. New charge back wire from the alternator runs under the radiator (zip tied to the wire harness thats there and is covered with wire loom) I have an 80amp circut breaker mounted near the intake (plenty of room). I do not have pics of this part of my system. Then charge back wire runs through the firewall (used a rubber grommet as well) down the passenger side of the car to the rear.
***NOTE*** I disconnected the oringal chargeback wire from the alt. It runs to the 80amp fuse in the fuse box. This fuse is screwed in with a 10mm bolt. The wiring was removed, keep the fuse and bolt for later.
Heres my battery and battery box. (don't mind that is not hooked up or bolted in, car has no engine at the moment) the top wire is the ground(bro robbed my terminal) On the positive terminal, the top red wire is the charge back from the alt. The lower red wire goes to the switch.
The switch (in the off position) is mounted to the body with an aluminum plate as a spacer. I found this allowed the switch to function better. The switch is made by Flamming River and has an extension rod. The lock cylinder was removed and the hole opened up with a dremel about an 1/8" on one side so the rod can move freely. The wire comes from the battery to a 100amp fuse (not sure if this is needed but I figure better be safe and 100amp is all they had, i wanted 80) Then from the fuse to the switch. On the other side of the switch the fuel pump rewire goes right to my fuel pump with a inline fuse in that as well. The main power wire from the other side of the switch goes back through the body of the car.
Shot of the rod coming out of the key hole in the car. When I'm not going to the track I can unscrew the rod and cover the hole from the inside with duct tape to keep water out. Call me ghetto.
Yes, I have some rust, subframe is coming out for bushings and paint. The car has been sitting for a year and gets driven in the winter and goes to the track every now and then.
The wire comes back through the firewall (another grommet) to this distribution block. The red wire on the right is the power feed. The black wire coming from the bottom is the starter power wire. (note; the main ground is near that one) The white wire coming out of the top covered in wire loom goes to the fuse box on the side that the old alternator charge back wire ran to. Lastly the stock fuse box that mounted on the battery was removed and the wires run into the block with stock size fuses.
***THOSE WITH 92-94 CARS***
You can do the same thing using a different switch. Get a switch that has a silver knob on it. Its a "turn off" switch. Remove your right rear reverse lens by removing the black side cover on the license plate side. Remove the 2 screws and pull the light towards the license plate (its kinda hard to do because there are 2 tabs that go into plastic inserts to hold it) You can bolt the switch in and simply reinstall the lens and light to keep things looking stock. It fits, I've done it. When you get to the track, unscrew the light, slap a 'shut off' sticker there and have fun.
I've done this set up on 2 cars. It kills all power to the car and fuel pump. Not sure if this is the best way but it works.
Good Luck.
Good Luck.
