correct way to wire a c.o.p.
Does anyone think that the above diagram for the AEM CDI is similar if not the same to the MSD DIS4?
AUTOMECH01, what coils and CDI are you running??
Any missing issues??
Plug gap and what psi at WOT??
hakcenter said:
I'm not AutoCH, but I run Buschur's COP on my stock ignitor gapped @ 25-26, seen 20+psi
Been messing around with the ecu's dwell time, doesn't seem to change anything, but w/e
What are you using to control your ignition? How is part throttle driving? I've seen too many misfire issues from these things at part throttle for me to install mine as my stock ignition has not failed me yet gapped .028" at 30psi. I just like the cleaner install deleting the coil pack, especially with my SMIM.
