Battery /ignition wire
kurt fuhlbrigge
92
Feb 18, 2008
canaan, New York
I'm installing a meth kit and it says it needs battery power and ignition power .Everything is going under the hood . The battery is in the trunck .Can someone give me some examples of battery/ignition power that I can easily find under the hood . And what they would fall under battery or ignition .Please . Thank you .
A battery wire would be anything that is "hot" (12 volts) all the time. An ignition wire would be anything that is only "hot" when the ignition is turned on. There should be plenty of hot wires under the hood even with your battery in the trunk. Just use a multi-meter and check the fuse box under the hood.
