COrrect bolt sizes for oil retrun line for 14b/16g 1g setup?
Spoolin4Ever
1,142
14
Apr 24, 2005
Moses Lake, Washington
Sure there are 5 threads asking this, but no 100% clear answer; what are the correct bolt sizes for the oil return line? I need to know both up on the turbo, and down on the oil pan.
I see it says use lock washers up top on turbo, and use flat or crush washers down below.
I see 3 bolt sizes mentioned within the various threads:
They are saying either M6x1.00x16 or M6x1.0x25 for bolting to the turbo,
M8x1.25x16 for down below?
So someone give me the right answer and we will all benefit! Yeah!:thumb:
Turbo Oil Drain Line to Oil Pan
(2) bolts, (2) lock washers, and (2) 18mm washers
shaft diameter x thread size - 6mm x 1.00mm
length - 25mm
thread length - 18mm
head size - 10mm
hardness - 7
Turbo Oil Drain to Turbo
(2) bolts & (2) lock washers
length - 25mm
head size - 10mm
hardness - 7
They are basically the same bolts they just use different hardware depending on which end of the oil drain you put them on.
:dsm:
