Spideydsm99
- 240
- 40
- May 30, 2017
Cherryville,
North Carolina
Hello fellow dsm people! I have a 99 gst with 231k still has the original motor and it's all stock. But it was pushing coolant and had no compression in cylinder 4. Turns out that was because of bent valve so I fixed that.
Now since I had the motor most of the way torn down I figured I'd do a balance shaft delete. This is where things get bad and I need help with. I took the oil pan off and noticed a bunch of crap that didn't look to good right in front of the oil drain inside the pan. It was mostly copper and 3 pieces of something metal and to thick to be a bearing.
and also this is all the copper that was with it. And a pic of one of the balance shaft bearings
the motor did not knock or anything. So what do you guys think I should do and look at next? Thanks guys!Attachments
I already have Evo valves in the head that I had to redo so I may do that. How much do they usually go for 100$?
