fwdturbobov1996
- 1,504
- 8
- Feb 27, 2004
Blue Springs,
Missouri
She started. Ecu was bad, got a new one. WOHOO.. ok few problems. Clutch wont disengage. When you push the clutch in the tranny moves. So common sense tells me to tighten the bolts. Which in turbo would fully make the tranny flush with the block and therefore the clutch will diseengage. Alsot exhaust leak easy fix. Another problem I have is when I rev theres like steam/pressure shooting out of the injector area. Bad lower seals that are on the bottom? Thanks in advance
