cooling system-coolant loss
zulimee
Dec 11, 2010
connecticut, Connecticut
my coolant filling the resevoir tank when engine hot.. and suck the coolant empty the resevoir at engine cooldown.. when i change the radiator cap 1.1bar coolant filling the resevoir.. and don't suck when engine cooldown.. the temp not overheating when i use 0.9bar radiator cap..
What the Hell are you even trying to say? Use proper spelling and grammar unless you do not want help and want this thread closed.
I think i know what your trying to say, i had a smilar problem with my car. It was the Gasket on the cap. It wasnt sealing very well so i cut a new gasket to the shape of the cap out of some foam rubber and problem solved. Other than that all i can say is to get a new cap for your car VIA the Mitsu Dealership.
i'm not use thermostat and always running fan. What if I use 1.3 bar radiator cap
