Coolant pipe
chadillac2820
277
3
Mar 2, 2012
newnan, Georgia
Is there an aftermarket coolant pipe that doesn't have the pipe that goes to the heater core and t body?
Why do you want to get rid of the heat? Do you drive this car on the street? You will regret it when your windows are fogging up.
I would just keep it open just in case you need some heat, ya never know even in my home state of ga, just in case, unless your headed to the speedway down there, only.
I cut mine off about an inch or so from the bigger pipe, clamped it shut in a vise then welded it. Worked great!
You may be able to flatten it and fold it twice then braze it closed. I have done this method on the ford EGR cross over pipe on the back of the heads.
  • Wanted 6 bolt NT water pipe
    • chrisman287
