Unused Coolant Ports
C89ZX7R
122
24
Feb 24, 2011
Richmond, Virginia
Any pros or cons about closing off the unused coolant ports on the head that dont pass thru the HG?
I know about the two holes I have to block off up front when using the front water outlet. Im not talking about those. Im talking about the long oval shaped ones around each cylinder that is blocked by the headgasket. Friend had one leak there on his into the chamber. Figured while Im having the two front ones closed off I might as well close the other ones too.
Found a picture of one
