Coolant leak
Jesse602
Jun 26, 2012
Delmont, Maryland
Okay so I have a coolant leak. I overheated on the way home from work. I checked it out and could not find any leak from any of the lines etc, but my thermostat housing seems wet. So I'm thinking get a new housing and thermostat? Also the majority of the coolant was a little to the right bottom of the housing so I'm thinking that's it? What do you guys think? eBay 1g new thermostat, and just get new hose to radiator?
Pull the t-stat out, put into a pot of boiling water and see if the plunger pulls the inner flange down. If not, your T-stat has stuck closed. Time for a new T-stat. Or, the housing gasket let go on you causing the leakage.
With T-stat out, flush the system completely to rid of corrosion. Put in new T-stat and gasket and torque the two bolts down evenly and in steps so one bolt isn't tighter than the other. Add 50/50 coolant and fill the radiator to the top, then fill the overflow bottle to the FULL line.
See what goes from there. - good luck - DSM
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
  • For sale 4G63 Powder Coated Valve Cover w/ 10an fittings & new baffles
    Powder Coated 4G63 Valve Cover w/ 10an fittings & new baffles $250 + shipping & paypal feesYou...
