420A coolant leak
Slow_Rs
50
Oct 23, 2020
glasgow, Kentucky
the car is dripping coolant from the side of the engine where the timing belt is, could this be the water pump? any help is appreciated
you don't need to remove the cover on a 420a. you can probably see it by just getting under the car but you might need to remove the A/c belt and move the compressor forward a little if its in the way.
The 420a also suffered from head gasket leaks due to Chrysler not drilling some head bolt holes deep enough, the bolts bottom out before placing the required torque on the head.
when i looked previously under i seen a stream going down the middle of the belt and then it would be flowing down and then dripping from the oil pan, i have inches of snow right now so it’s hard to get up under it, i noticed the leak once i replaced the thermostat and started to refill, it’s definitely coolant leaking, before the car went down it would bounce up and down in temperature and level out sometimes to where it needed to be but i figured that was just the thermostat, i don’t think it was leaking prior to the thermostat change since i filled it up about a week before i did the thermostat and it wasn't leaking at all
usually when the temp gauge is bouncing up and down, it mean you are low on coolant. Its bouncing because the coolant level is low enough that the gauge sending unit isn't fully submerged all the time.
The weep hole on the water pump is under the sprocket or whatever the fuc you call it. the part the belt spins, so when it leaks it will drip off it into the timing covers but it will also run down the body of the water pump and drip from the spot you see in the picture from my other post.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
