Coolant leak help pls *video*
hey, so i did a bit more searching. And it isn't a o-ring. but there is a hole in the water pipe. How do i go about replacing this?
get a picuture of the leak, and if needed or within your means, open pic in MS paint and put a colored circle around the leak so we can better tell you how to fix, so far your being a tad vague about the leak, pics are better than words in cases like this , it's like me saying there's a hole in my fuel line by the filter how to i fix it.. (being that there's both steel and rubber lines and two types of fittings that could be leaking it would be hard to get help with that vague description, so more specifics would be needed to answer just as we need in your case)
