conversion gasket set
mikeesho1
Jun 28, 2011
romeoville, Illinois
Hi im lloking to replace oil pump seals etc. i found a gasket set from fel-pro. I dont know if this set will fit my motor fel-pro cs 9086-1 also does the balance shaft elimination kit free up any horsepower. Also wanted to know if this is a wise idea to eliminate it
search for a part numbers for the gaskets, chances are you'll be fine. as for the balance shaft elimination, i dont think you'll notice a difference in horsepower, might rev up slightly faster due to the lack of resistance of it being there, but eliminating this is usually a preventative maintenance mod. "it's for your butt not your motor" take a look at this and it should help you. Balance Shaft Eliminator Kit Install
