twzted_gst
- 0
- Dec 5, 2010
crestview,
Florida
When I take my water cap off I have constant bubbles and the bubbles look frothy. Also when I take oil cap off there isn't as many bubbles. Any ideas? Blown head gasket?
A compression test will tell you if you need to do a leakdown test.
Not necessarily. I just had my head gasket start pushing coolant last week, and the compression test showed all cylinders great at 180-185 psi. The leak-down test showed cyl #1 leaking into the coolant though, which was verified when the head came off.
A leak-down test will find smaller problems and is usually the better choice out of the two. Compression tests are good for finding "big" problems that drastically affect cylinder compression, but they won't show smaller issues or more dynamic problems.
My case was a good example; I could only find air leaking into the coolant if enough pressure built up in the cylinder, at which point it would push past the head gasket and into the coolant. It then took about 10 seconds for enough pressure to build up again and cause more bubbles. By injecting air into the cylinder continuously at high enough pressure I caught it, but the compression test would never show any symptoms of that problem.
I wonder if that's my problem; my compression test came back good, with similar numbers to yours, actually. After I give 'er a footful, I almost always smell coolant, but I never smell it while I'm under boost. I can't keep coolant in the damn thing, and if you take the radiator cap off, it looks bone dry, but NEVER overheats, no matter what the outside temp is. I've long since given up filling the coolant up. No leaks that I can find, either. The temp gauge never moves past normal, even when I was at the track doing 3-4 back-to-back runs...
It runs fine, other than smoking when it idles for too long. I think that's from bad valve seals, though...Aha!I wonder if that's my problem; my compression test came back good, with similar numbers to yours, actually.
