confusing car
sachamo88
Feb 19, 2011
molena, Georgia
i recently came across an issue with my 420a that no one has been able to resolve yet and figured id try here
ok first off its a 1999 eclipse gs 420a auto
im getting no fire from the coil ( checked 4 different coils brand new and 2 from running cars)
cam and crank sensors are brand new and working perfect
asd relay is brand new
pcm is brand new from mitsu
i have no power going to the coil at the plug but i have ground pulses at it when trying to start the car
car turns on fine great compression but no spark
can anyone point me in a general direction on something i havent replaced or repaired yet any help would be much appreciated and thanks :aha:
Do you get power and ground to the primary curcuit on the coils?
So your car turns on without a spark? I think you mean turns over. It might be something small you overlooked, have you checked your engine link fuse?
So trace back the power wire using the service manual. Is there power coming from the ASD relay to the coil? There is obviously a break somewhere in the circuit. Bust out the DMM and start probing.
  • For sale 4G63 Planetary Gear Sets ( for 1G & 2G )
    Planetary Gear Sets $175 a piece + shipping & paypal fees* fit 1G Auto GSX/GST * fit 2G Auto...
  • For sale 4G63 Motegi Traklite Wheels & Tires
    Motegi Tracklite Wheels & Tires $650 17X8 5X114.3 Offset +45 2 Toyo Proxes 235/45R17 Tires 2...
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
