Confused about water lines on 2g 14b
rob1621
387
Jan 4, 2007
Wisconsin Dells, Wisconsin
So im installing my 2nd 14b but this 14b is slightly different than the on i had before. The water lines are positioned differently. If the turbo is sitting on the car, there is a water line behind the turbo, then there is the oil feed on top, and then there is a water line in front. and under that waterline is a little plugged hole.
Im thinking i got a 13g...whats the difference between 14b and 13g?
also where do each of the waterlines go? the one in back goes to where? and the one in front goes to where?
Hope this explanation is enough for ya, if not just let me know...
There should be a 14b P/N stamped on the side of it so you can for sure tell. Heres the list of them...
49178-01010
49178-01030
49178-01400
49178-01410
:dsm:
Thanks bro! helps alot with clearing up what my turbo is. But does it matter which coolant line goes to what on the motor?
Like what exactly does the rear one hook up to and what does the front one hook up to?
You really can't mess up the coolant lines because of the length of the rubber hoses coming off the t-stat housing. The one that goes to line around the back of the turbo won't be long enough to reach the hardline that goes around the bottom.
:dsm:
