Completely Stock knocking
newdsmtnr96
250
Apr 16, 2005
Des Moines, Iowa
I did a full tune up, fixed the over-boosting, Fixed the water leaks on the car I just bought, Bought a wheel hub instead of bearing, I can't figure out this knock problem. I researched and that's how I figured the over boost and the leaks and the plug gaps for tune up. I want to mention that this car is completely stock other then intake and exhaust. I did mess with the Biss screw on throttle body it doesn't knock super hard at 1000 rpms at idle. But if I lower it just a little it knocks like every once and a while. This may be a dumb example but Best way I can show you. (if I had a camcorder I would use it)
idles fine..... Knock....fine..... Fine fine... For a while knock knock
what is your normal idle?
Note: I found knock threads but they all have modifications i have 2 mod's.
Im going to assume that he is hearing it. What else would he want to camcord for us. If you can hear a knock you probably have a serious issue.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
