Colt Eprom in Talon
CrazyM
409
3
Jun 22, 2006
P.G., BC, Canada
Hey guys I recently got a colt EPROM ECU. Was told it is identical to the 1st gen ECU's. What all needs to be done for it to work in my car?
I'm assuming get a different chip programmed..
As long as it was from a 4g61t it will work, it's just the mas and injectors are smaller and you need to compensate for that some how, either with a safc or chip.
I've heard that they were supposed to plug and play. REALLY could use a wiseman or something on this one buut...
The Eprom I have: MD131842 1989 Mirage DOHC FWD TURBO E2T34376 Federal
When I turn the key to ON, the check engine light comes on and stays on, and the stock boost gauge immediately goes all the way to its highest mark...
I have switched wires 6 and 14 and still no start.. ANY ideas?
The colt gt/migare wiring harness is the same as '90 eclipse/talon/laser so you do not need to switch the pins. Are you sure the ECU is not bad?
I was told it came out of a running colt that had been 4g63 swapped. I'm thinking maybe the chip is messed up?
I should be getting a chipped programmed and sent up to me sometime soonish and hopefull that solves the problem..?
Is it an eprom? Do you know what it was chipped for if it is? If it came from a 4g63 that was running fine, there should be no reason it doesn't just start right up.
What condition are the caps in on the board? The capacitors are known to leak on to the board, causing the ecu to work funny, or not work at all.
sry to drag up an old thread, but is the 89-94 Mirage the only years with a possible eprom ecu? I was in the junk yard yesterday and a 1.8L Mirage had an Eprom ECU. to bad someone else was there getting it.
And since I am AUTO AWD turbo. Which Mirage EPROM ECU would work;
