97 talon eprom
The only way you're going to be able to use DSMLink is if you do a TOTAL non-turbo to turbo swap, including the motor, wiring harness, transmission, and ECU.
If you're just talking about using your current 420a motor and putting a turbo kit on it, then you will not be able to use DSMLink because you're still using the Chrysler motor and therefore must still use the 420a ECU. DSMLink is for 4g63-equipped vehicles ONLY.
