PlanZero
- 1,516
- 267
- Aug 13, 2013
Easton,
Pennsylvania
I know this is a common thread but I still haven't found an answer.As the temperature drops it's been getting harder to start my 420a. I swear it only helps when I give it a little gas before I crank. If I give it gas as I crank it tends to sputter and die. I replaced the ect and battery, and I'm getting a cylinder 3 misfire as well as an o2 sensor unreadable code on the ecu. Could this be an injector problem even though she runs fine when she's warmed up? Mind you I haven't owned this car long so I don't know if this will happen all winter when the temperature is cold all the time.
