cold weather start problems
PlanZero
1,516
267
Aug 13, 2013
Easton, Pennsylvania
Simply put, the colder it is the harder it starts after sitting overnight or after work. Above freezing she starts fine, but when its twenty degrees out it takes a few tries; below zero it takes fifteen tries. It will occasionally start for a second then die. I've replaced the cts, the battery and plugs. Wtf? Any suggestions?
Not possible. Gotta park on the street. Anyway I went to auto zone today and I still have a cel for the coolant temp sensor. I don't understand. I replaced the cts, the cts connector, the thermostat and radiator months ago, and I thought the ecu would reset when I put a new battery in. Most likely, the cts is still the culprit, I assume? Any thoughts before I order another sensor and change that PITA in this weather?
What is the car doing. Is it having a hard timing turning over? Is it cranking continuously but just not starting?
Are you running any tuning software? How are the plugs looking? Sounds like it might be getting too much fuel.
