Coil On Plug Wiring Problems Part2!!!
1995badgsx
80
May 27, 2004
columbia, South Carolina
i just bought this cop setup from punishment, it looks awesome, but, the wiring instructions that came with it are way off or i'm a idiot, it says remove the wires, coil pack and power transistor completely.
then says find the black wire with white stripes, yellow wire, yellow with red stripe, and black that are located on the power transistor harness (sounds easy)
but my wires on mine are no where even close (ive got 7 wires 95 gsx)
theres a blue/black, 2 black with white stripes, 1 orangish with red stripe, 2 blacks with silver specs, and 1 white with silver specs????
on the oem coil pack harness theres 3 ( blk/white, blue/blk, blue/red)
IM LOST.......................HELP IF YOU CAN......LOL
o, and the wires on the new setup are white, brown, green, and yellow????
are you sure it said the power transistor also?
the individual coil setups I know that run without a transistor are the extreme motorsports(efi-systems) coils?
coil on plug kits are usually wired in by cutting the coil triangular plug ONLY!
you would then wire it in accordingly.
hope this helps. :D
it does say right on top of this sheet
remove wires, coil pack and power transistor????
ok, talked to tc at punishment he said the green wire of the cop setup is for cylinders 1&2, and the yellow is for 3&4, and the white is a 12V power, and the brown is ground
on my factory oem coil harness there are 3 wires (1 blk/white stripe, 1 blue/red stripe, 1 blue/black stripe)
how and where would some of you recommend to wire up these wires, my thoughts were that 2 of the wires on the factory oem coil harness are for cylinders, while the black is a ground, but i'm not sure???
