BLACK'98DSM
Moderator
- 5,491
- 3,001
- Feb 9, 2019
Alabama
My master cylinder and my slave cylinder are both leaking fluid which leaves it dry after every time I drive it. I am going to replace both of them as soon as the parts come in. All I need to know is do I have to pull the engine or trans to do this? Or any other major components that would take tons of time? It appears that I can just pull out both the cylinders with only moving the washer fluid tank, but I want to make sure.
It's not that easy to do if you can't fit under the dash of your car!
