ErikTande
Supporting Member
- 1,522
- 595
- Dec 17, 2012
Centennial,
Colorado
My clutch stopped working today, it pushes to the floor and stays there. I can grab it with my hand and pop it back, but it doesn't work or actually engage the clutch. I did some searching, and from what I can tell I'll need to bleed the system and install a new Master and Slave cylinder. Does that sound about right?
Do I need an OEM one? They're $140 on extreme psi
EXTREME PSI : Your #1 Source for In Stock Performance Parts
But I can get aftermarket ones for like $40 at my local parts store. Is it worth getting the OEM?
Here's what led up to it today:
I cleaned my engine bay with degreaser and a light pressure wash rinse today, drove it home, noticed some fluid in one of the spark plug cylinders (I could hear it bubbling), but that drained out on it's own. I drove it around some more to make sure it was ok, and it was running fine. So I parked it and started working on it for my original purpose of replacing the crappy knock off, non recirculated BOV that was on the car when I bought it and re-mount the catch can. I replaced it with an OEM BOV. Again, no problems immediately after. I drove around some more, ran some errands, got some food. Then on my way home is when the clutch problem happened.
I took some video after I cleaned the bay and drove home (I heard some bubbling so I grabbed my camera). I'll post it here in about 30 minutes (going to edit some clips together)
**EDIT** Video added.
[ame]http://youtu.be/_LOsVRS02Ls[/ame]
I love this car though, it's worth it. I do smaller maintenance things myself when I have time, but when something comes up like not having a working clutch, I need it fixed promptly and correctly, which isn't me at the moment.
