Replaced battery and turbo timer stopped working?
synthetek
DSM Wiseman
1,657
89
Dec 13, 2005
La palma, California
My Battery died and I had to replace it, after putting in the new battery everything seems normal but there is no power to the turbo timer? It is an HKS Type 0 and it is installed with a harness. Everything is plugged in and nothing has been touched except the battery. Did it just die? any fuses I should check?
Thanks
You can get on the HKS website it tells you how to "reset" it after power has been disconnected.. I believe you hold in the top two buttons until it turns on...
Take both terminals off the battery and it will reset the tt. Put them back on and everything should work again.
