turbo timer not working
JUAN2333
Apr 28, 2006
chicago, Illinois
I Installed A Greddy Turbo Timer With The Harness I Also Wired It Up To The E-brake When I Turn Off The Car It Turns Off It Does Not Count Down
The Car Has The Factory Alarm. I Checked All The Wiring Cant Figure It Out Please Help I Need Some Help
Make sure the ebrake wire is properly grounding out when the e-brake is applied, or else it'll just turn off like you have described. You could temporarily connect the wire to a known good ground and test it to rule this out.
You need to go over all your wiring again. Make sure you have the e-brake wire connected properly and make sure you have a good ground.
