clutch speed bleeder upgrade
Do it. And put them in your calipers if you can I have them on all calipers and the slave cylinder). Makes one-person bleeding extremely easy since the bleeders work as a check valve. You just crack them open 1/4 to 1/2 turn, then pump your clutch until you see no air coming out (while making sure to keep the master cylinder reservoir full), and then close it. Very easy!!
SB1010 is the model you need.
I also use Speed Bleeders on my calipers and slave cylinder. They've been on since 2004 without issue.
Makes life a whole lot easier as you no longer have to get your GF/wife out to do the push-hold-release-hold-etc, etc thing.
