clutch slave
munk
161
Mar 3, 2008
vassaboro, Maine
I am leaking fluid from front the line that goes in to the the slave cinder how do you go about and fix this. should i just get some ss lines and call it a day?
Its a small leak it leaks harder when i have the clutch pushed in and i rev a lil. its been leaking a little over 6 months now. and its finally gotten time to get that issue fixed do u think i should just get some ss clutch lines there like 35 bucks on ebay. Im just realty getting tired of having a hard time shifting in to 1st i bled the system the other day and i got 5-7 realty nice shifts outta the car b4 it started getting crappy again.
Looks like its about time to replace that slave judging by the rust on those pics ;)...
New copper washers should be all you need to fix that (which is included when you buy a new slave) :sneaky:
OP
Is your clutch also stuck on the floor when you throw it to neutral from a high speed? My is doing that and I wonder if our problem is related!
Im guessing the slave cylinder and then second problem could be my master! I just finish bleeding it and I ALSO got a few good shifts out of it before the clutch starts to get stuck on the floor again! But when I come to a full stop, it pops up on its own!
