Clutch screaming....HELP!!
Matrix_Blue
Oct 30, 2004
Marble Falls, Texas
Alright first off sorry if this is already posted but im at work and my time on the comp is limited....So i replaced the clutch in a 1990 tsi turbo awd right, well i put it back together and then went to drive it, no go the tabs on the throw out bearing that hold it to the fork were flatened out , so i re-did the clutch(thank god for warranties)and now i have a screaming noise that i had the first time when the tabs were flattened but the tabs are fine now. is the clutch just not bled enough so it is barely hitting the fingers on the pressure plate and making this noise or is it something else...I also have no gears from a dead stop,but if i shut it off and put it in first i can shift with the syncros or use the clutch .but if i use the clutch it makes that god awful noise and it grinds MOST of the time but not always, PLEASE somebody tell me what i need to do to fix this so i can take it to my house its sitting at my parents house 2 hours south of me and they are getting tired of it sitting in the drive way torn apart!!!
Well can anyone give me some ideas on this im going to go home today to look into it again and i need some input, something is better than nothing!! please somebody.
