Clutch help
Goobdog
163
6
Jul 14, 2004
Louisville, Kentucky
Hello I have an ACT 2600 kit in my car. I had to replace the tranny a while back and ever since then its been weird. I bled the slave cylinder and the pressure is fine its just it seems like the release point is in a different spot everyday. Im thinking maybe there is still air in the line but im not sure. Also I was at the dragstrip the other day and I was holding the rpm to launch and he was taking forever to let the tree down and the clutch pressure went away like you opened the slave cylinder bleed valve and you could smell clutch but it still held the car no problem and it didnt do it again after that. When I had the transmission out the clutch looked great but the pressure plate had a few small burn marks but nothing too bad. What do you guys think ? Thanks
