Clutch problem
DSM Phantom
47
Oct 6, 2013
Grafton, Massachusetts
Im having what is called clutch pumpup
Have adjusted the master rod many times and sill cant get the slave to move by hand
No air in system blead properly
Can get clutch to grab low after driving pedal gets high and slips under boost
First manual dsm please help
96 talon 6 bolt swap
Come on nobody wants to answer?
Sounds like you need a new clutch master cylinder. Appears that the seals aren't letting fluid back into the reservoir when the pedal is released which slowly builds pressure in the line causing the slipping. Would almost definitely be internal to the master cylinder if the pushrod is adjusted properly. Rare case would be sticking slave piston, but that wouldn't be my first suspicion.
gaurentee its the slave cylender i went through a bunch of them if you put a bigger aftermarket clutch in them especially the 7 bolts youll have that problem and yes you gotta bleed them a good bit also
theres a resivoir that can be elimnated on the tranny it solved my changeing of slave clyenders car was slipping also and didnt want to go into gear
also known to cause crank walk on 7 bolts
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
