Clutch pedal sticking down
Dsmj89
3,249
14
Nov 11, 2008
Miami, Florida
Hey guys how's it going ? Been working on my friends talon lately, and yesterday i had another friend install a new clutch on it.
Problem is, before and even still after the new clutch, after you step on it WOT and shift the pedal sticks to the floor, in turn not allowing you to get in gear.
Could a bad slave cylinder be the cause of this ? My friend also has in the trunk a stainless steel clutch line which i will be installing tomorrow.
Anyone have an idea ?
Haven't checked the return spring, i will look into that. And the slave cylinder is the oem one, has never been touched.
You mean it is sinking and not coming up. When that happen to me it was my master cylinder. I change it and no more problems. A master cylinder don't have to leak to tell you it's bad. Age can also kill them.
Edit:
Also there is a plastic tab inside the cylinder that will not hold the pressure so it will sink.
Thanks dreamt that info helped. I'll tell my friend to start looking into replacing both the slave and master at once.
Almost sounds like a slave or also needs to be re bled. Just bleed it really well. If you do the stainless line then also take the bleeder out of the slave cylinder and you will see a restrictor in there. Just take a magnet and take that out if you want a better pedal response. There is a write up about it on VFAQ Site - Visual Frequently Answered Questions. Yeah its also good if you haven't replaced the clutch master and slave cylinder it is probably time considering the age of our cars.
every time i have to bleed my clutch the pedal goes to the floor and then i have to pull it back up but after that its fine . i think you still have air in the system .
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
