Clutch Master Cylinder differences...?
suprdave09
42
Sep 19, 2004
Troy, Michigan
Im in the process of changing out the clutch master cylinder and i was wondering the difference between the two parts before i order the one i need. I am getting told by all the parts salesmen that there are 2 clutch master cylinders one says with speed control and one without. Does this mean cruise control? Also if i removed cruise control would i still need the one with cruise control?
Yeah thats cruise control, you dont need to run the cruise master, but might as well just in case you do like I did and change your mind and hook it back up, they should be the same price. The cruise master just has a port in the front to act as a cruise kill switch if you touch the brakes. Internally the bore is the same and the actual brake line ports are the same. Hope thats what you needed.
