clutch making a weird noise
skyrone
230
Jul 12, 2007
Gillette, Wyoming
Hey guys i just changed my throwout bearing and pivot ball, i put a washer behind the pivot ball to give it a little bit of a shim. put it all back together and started it up sounded fine. as soon as i went to let the clutch out it started makeing a noise like running a stick down a fence or putting a baseball card in your bike spokes. any body have any ideas?
Did you torque everything down to specs. It sounds like one of the teeth on the pressure plate could not be uniform and cause at weird noise. Other than that i could only say a manufacture defect TOB
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
