my clutch makes a weird noise =(
stevew1
108
Jul 24, 2004
new/east brunswick area, New Jersey
i just noticed this, after i let go of my clutch (in neutral when i was testing it out), i hear a squeak..can anyone gimme their opinion on this? i checked the clutch fluid and it's at good level..if and where should i put lubricant?
I have that little squeak after clutch release from any gear but only under moderate to full boost. I have just changed the master and slave cylnder so I suspect air bubbles. I'm rebleeding the system today and see what happen. The squeak comes right after the BOV releases.
FourG63 97GST said:
hmm could it be the 1G bov squeek
yes there's a squeek after the whoosh :)
I think you're right. I took it out for a test after I bleed the clutch and found out it actaully does it when I let off the throttle after boosting, nothing to do with the clutch. So is this normal?
Sorry for hijacking your thread stevew1, how's your squeak coming along? Where is it coming from? Inside or the in the engine bay? If inside, It's probably your pedal assembly. If in the engine bay, get under the car where the slave cylnder push rod and the clutch fork is and have a friend step on the pedal. If the squeak is coming from there, It's probably a bad TO bearing. I have that squeak too after installation of act2600. The shop who did the install said it's a defective TO bearing, was going to charge me $250 to go back in and replace it (Didn't buy the parts from them) so I just kinda left it.
