clutch just isn't right
avaien
242
24
Nov 30, 2003
Cincinnati, Ohio
I put an act 2600 in my car over 10,000 miles ago. When I push the clutch in it is not smooth and makes a squeeking sound. Also when engaging or just letting of the throttle fast it sometimes makes a clicking sound. What would this be? The clutch engages pretty good but sometimes just wont go in.
Start by checking you clutch fluid, bleeding the system, checking engagement point. If all that is good and you still have the problem. Sounds like the throw out bearing to me.
It may be. That is just the stuff you should do first to find out what the problem is.
For example: Low on clutch fluid? Maybe your master is leaking. Just go through and do all that little stuff and you'll find the problem pretty quick.
