Clutch Pedal Adjustment isn't working..
apache211
40
Jul 5, 2002
Lincoln, Illinois
Any help or suggestions would be great on this one....
I just replace the clutch with a OEM clutch kit, bled the system, then adjusted the master cylinder piston accordingly. Each time I did an adjustment to the pedal, I did a test drive, and each time I drove it, the clutch slipped. On the last adjustment, I turned the piston all the way counterclockwise until there was only about 3 threads sticking through to the inside of the clevis that attached to the pedal itself. I started it up and put it in gear, it moved a little bit, I reved it up to about 6k then it the rpms dumped to 0 and the engine died.... now it won't even start... all this for a clutch.. hmmm... :confused:
Is there fluid in the clutch master cylinder? Bleeding the system and not refilling the resevoir will get you every time. Another thing, "on my car" the adjustment nut has about 5 threads sticking through it, maybe 6, I can't remember.
Do your pedal have normal pressure?
Here's a link I found quite helpful in setting up my clutch:
http://www.taboospeedshop.com/DPCS.htm
Other than that, You shouldn't be having this problem.
Hope that helps.
gsxtacy
apache211 said:
went out to the car, reset the ecu by disconnecting the battery, for an hour, and still the car won't start...turns over, but won't start
nix that one.. i unplugged to ignition control module and reseating the plug..
fired right up.. :confused:
hmm... these cars have demons. LOL
  • Wanted 6 bolt NT water pipe
    • chrisman287
