1cleangsx
- 1,777
- 2,404
- Sep 28, 2013
Cheyenne,
Wyoming
Hey guys I’m hoping someone can help me out with this issue. I’m 200 miles or so into my build, had some clutch drag like most, had it fixed apparently for a day until I adjusted the rod some more and it’s been a downhill journey since, haven’t driven the car in the past month because of this issue.
So it started with me replacing my 6 year old master with a new OEM unit. I swapped out the 1g rod with a 2g rod for more adjustment as this method has worked for some. With the 2g rod I was pre-loaded, couldn’t move the fork by hand so I adjusted the rod out (towards the pedal) like in the Jacks video until I could move it.
With the car running it would NOT go into 1st gear, no matter how far in or out I adjusted the rod, or shift linkage, no 1st gear, so I never even backed out of the driveway. So I put the 1g rod back in, along with replacing the slave with a new OEM unit, restrictor removed like jafro did, bled the whole system until there was no more air/bubbles in the fluid, but again, no matter the position of the MC rod and or pedal height, the fork won’t move.
I cracked the slave bleeder just now which of course let the fork move some by hand but not the full normal range. I don’t know WTF? I’m wondering if I damaged the bleeder valve on the master or what I don’t know. Any thoughts or tips would be greatly appreciated thanks guys
Sorry I didn’t mention this set up is a Jacks trans with just 200 miles, same as the clutch fork, tob, south bend clutch/act flywheel all just 200 miles.
That’s my theory anyways, when I essentially over adjusted my brand new master with the wrong part it messed something up. But who knows, I will order another new master, but just for $hits and gigs I’m gonna throw my old undefiled master back in to see what happens, I’ll report back
I tried a quarter turn out with fork movement, and several turns out with fork movement, no 1st. I even played with the shifter linkage while idling no change. If I went to 2nd gear first it would go, but I didn’t even bother driving it like that. So I put the 1g rod back in and here we are
