Clutch failure after freeway offramp semi crash
jdmforwalteria
Oct 26, 2012
torrance, California
So basically I just bought a pretty new used 97 eclipse gst, I was comming off a off ramp because I was going down the wrong free way and the off ramp banked way harder than I expected, going to fast my brakes locked up and i drifted side ways, my car hopped over like almost a foot of curb and into a 45 degree downward angle of ice plant and dirt. stuck and unable to drive my way out, I had to get it towed out, at first the car had power, and with no check engine lights and minor structural damage to the car I was going to attempt to drive it home. Then I noticed the clutch felt weird, like every time I shifted the reach got longer and longer untill it would only engage right as i fully depressed the clutch, then nothing. My engine was still running and there were no leaks under my car that i could see (it was at night). So I towed it to a shop and are hopefully gonna get it diagnosed tomorrow. Any idea what that might be specifcally though? how much is this gonna cost me? Is it my clutch or tranny? I honestly dont know too much about clutches or transmissions I'm kinda mechanically inclined but no master or anything. thanks
It could be a number of things. Kind of sounds like a master or slave cylinder issue but may not be. You may have knocked something loose when you hit that curb or worse cracked your bell housing. I doubt it's your transmission itself though, probably a clutch/pressure plate/throw out bearing issue. You won't know until you look at it.
sounds like you may have punctured a hole in the line to the slave or ruined the slave itself. Hydraulic clutch systems don't take to air so well. ;)
Now, after it gets fixed no more driving like you are in hazzard county. Them duke boys are up to no good... ROFL
